2 members (NJC, baldeagle),
57
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#33204 09/05/2003 10:11 AM | Joined: Jun 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2001 Posts: 85 | I just picked up a 292 L6 for a core/parts block -- the seller said it was out of a '72 truck. He probably wasn't lying, but the greenish color, weird fuel pump and smaller diameter [7/16"] flywheel bolts led me to believe it's actually a '63. According to Santucci, the '63s had a forged steel crank. The ser no stamped on the distributor pad is: FIII6PG. Any way to run the numbers? Thanks.
Every 25 years I like to rebuild that 292 just for GP
#33205 09/05/2003 1:33 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You need the casting numbers from the head and block to do it right. Santucci has a listing in his book, also there are lists at Inliners web page
Fred 52 3600 69 C-10
