6 members (Stovebolt48, Hotrod Lincoln, FishinToms53, 50shep, Millenimech, mason86), 52 guests, and 5 robots.
Topics128,030
Posts1,055,428
Members48,422
#331779 11/02/2007 2:01 AM
Hey guys never replaced a distibutor before. Replacing old with new HEI. Any tips. All info would be greatly appreciated. Not sure on wiring.
I have a 235 with dual Carters, I think the HEI will make it run even better.
57thekid,
Is this a genuine GM HEI? Your rig must be converted to 12 volts already. This ignition systems needs full voltage, so dump any type of resistor, wire or ballast.
Wiring is a conventional switched ignition wire from key...on when ON. If you are careful, you can pull the old and stab the new and that part is done. Rotation and wire order are the same.
I'll assume you have done the necessary machine work on the distributor as a GM HEI won't fit unless modified. More help on the way.
Stuart
atomarc #331837 11/02/2007 3:24 AM
I bought one already tp drop in. I have it switched, but now I need a hold down plate. Anyone have ideas?
