4 members (Southerntruck, Samantha, TUTS 59, tclederman), 106 guests, and 3 robots.
Topics128,036
Posts1,055,458
Members48,422
#33145 01/16/2004 11:04 PM
Hey the Pork is back-
I need to install my new cam gear on my new cam. I placed the spacer ring and the thrust plate on the cam and then put the key in. Now the cam diameter is like .005 less than the diameter of the shaft. Any tips on getting the cam gear on? Can i just press it on or should i heat the hell out of it?
thanks
pork-
1959 Chevy Fleetside 3100 Series BBW
#33146 01/17/2004 12:22 AM
Use your BMFH. eek eek eek eek
NO WAIT Just kidding.
#33147 01/17/2004 12:24 AM
I just had a Cloyes cam gear pressed onto a Howard's M4F 3/4 cam using a 20-ton hydraulic press per the instructions from the maintenance manual for my 261 chevy engine.
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
#33148 01/17/2004 12:38 AM
Quote
thanks
pork-
I say both heat it, then press it on. That's what I did with the cam gear on my 292. 4+ months and no problems.
-ftyler
#33149 01/17/2004 2:15 AM
Junior Member
Junior Member
I just installed a new cam gear on a new cam, I let it boil in water for about 10 mins. Then used a 2 pound hammer with a block of wood, worked like butter.
Stock and loveing it.
#33150 01/17/2004 7:45 AM
The Chevy Inline 6 Power Manual (great book) says to put the cam in the freezer overnight, then heat the gear in the oven. Check out the book for the exact prodcedure, or ask over at inliners.org.
1954 GMC De Luxe COE
#33151 01/17/2004 4:44 PM
Thanks for the reply's.
I think since I don't have access to a press that I will try sticking the cam in the freezer overnite and I will boil/bake the gear and try and pound it on. I'll let you know how i do!
pork-
