1 members (1 invisible),
108
Mod | | | Forums66 Topics128,193 Posts1,057,256 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 10 New Guy | | New Guy Joined: May 2005 Posts: 10 | Hi, I took the old 3 speed manual trans. (with the granny low) out of my '57 3100 in favor of an automatic and now I want to sell the old 3 speed. I'd like to know what exactly it is when people start calling me and asking.... are there I.D. codes on the trans.? I found a few sets of numbers and letters like GM18 and 591668, K956 and GM591953, K1256 T. Any help is appreciated, Thanks | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | flyinv55, I might be all wet on this, but if your transmission has 'granny' in it, it would be more correctly referred to as a 4-speed....a SM-420 by name. This is a very popular (or was) transmission with Jeep people, and just a general all around good tough transmission. Good luck with the sale of your Muncie SM420. http://www.novak-adapt.com/knowledge/sm420.htmStuart
| | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | If it has a 9 bolt side cover it is a Warner HD 3 speed. They are about the same size as the SM420 4 speed and low gear is really low. Good HD trans but not very common or popular. If it has a 4 bolt side cover with a long tail shaft - total length of the trans is 22", it is a regular 3 speed also known as an SM318. Lots of them out there. Fred
