4 members (dt235sd, Rich'sToys, wilbur53, Stovebolt48), 173 guests, and 3 robots.
Topics128,115
Posts1,056,288
Members48,439
I
I Offline
I have a 228 block that I'm scrapping and was curious if the front engine plate is the same as the 54+ 235.
Does anyone know if the engine plates interchange?
Greg, that plate does interchange with the chevy plates. There are some NOS ones that pop up a lot on epay starting bidding at $30 rather frequently. It is useful to peolple like myself who are placing a later sidemount 270 or 302 in an older chassis.
The front timing cover is the same as well.
I
I Offline
Thanks John.
You read my mind. I'm pulling the plate off to replace a plate on a side mount 235 that I pulled out of a car. It's probably easy enough to punch the holes in the existing plate but I didn't want to throw away something that is useful.
Greg
It's a lot easier to drill the new holes and square them with a file than it is to pull the oil pan, the cam cover, the rockers, the tappets, the cam, to get the plate off and put a new one on.
