| | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | I have a 228 block that I'm scrapping and was curious if the front engine plate is the same as the 54+ 235.
Does anyone know if the engine plates interchange? | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Greg, that plate does interchange with the chevy plates. There are some NOS ones that pop up a lot on epay starting bidding at $30 rather frequently. It is useful to peolple like myself who are placing a later sidemount 270 or 302 in an older chassis.
The front timing cover is the same as well.
John | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Thanks John.
You read my mind. I'm pulling the plate off to replace a plate on a side mount 235 that I pulled out of a car. It's probably easy enough to punch the holes in the existing plate but I didn't want to throw away something that is useful.
Greg | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It's a lot easier to drill the new holes and square them with a file than it is to pull the oil pan, the cam cover, the rockers, the tappets, the cam, to get the plate off and put a new one on. | | |
