0 members (),
88
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 65 | Installed new pilot bushing(brass)in a '62 235 CI while replacing clutch, pressure plate, TO etc. Drove brass pilot bushing in with big wooden dowel so not to damage. Bushing seems to have deformed at engine end of bushing and transmission shaft did not want to go in easily. Picked up new pilot bushing but did not notice until getting home that this one is steel. Does it make any difference which is used assuming that I lube the steel one, but not the brass type. Thanks Willie | | | | | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | The brass(bronze) bushings are oil impregnated,,I dont think ive seen a steel one............!!?? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | My '55 235 uses a steel pilot bushing and for years now. It replaced another steel one inserted by GM when the engine was built.
Drew
| | | | | Joined: Mar 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 65 | Thanks for the info. Will install the steel one when I get a chance. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | By steel one do you mean the one with the rooler brgs. inside? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 65 | This one is just a bushing, not a bearing. I have seen bearing as well as bushing available for this model. The engine originally had a brass bushing instead of a bearing, so stayed with bushing. | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | through it in the freezer overnight before you install it. some light heat on end of crankshaft using a heat gun so you don't damage the seal and bushing will slip in easy. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I'll bet it's actually bronze, not brass. Mine had a bronze bushing. I have seen them that have a steel backing, but the actual load surface was bronze. And the freezer trick works very well. I didn't use any heat, just freezing the bushing, but it worked very well.
Bill Burmeister | | |
