4 members (Bucker, Nick in Manitou, Shaffer's1950, 1 invisible), 220 guests, and 2 robots.
Topics128,189
Posts1,057,337
Members48,469
A dumb question. Some of you all have referred to a 10 bolt and a 12 bolt, which is the number of bolts in the carrier (I guess)and some of you have referred to the ring gear size (I think) of 87/8" and 93/8" . Please help me with these definitions in terms of this:
I have a '62 1/2 ton c-10. If I were to take the differential out (3rd member) of my truck, what info or measurements do I need to identify what it is so I can get the right parts for it. I am excluding the gear ratio which I know how to compute. Thanks in advance.
Taking the differential out is not the same as taking the third member out. Only certain axles have a "third member". The most popular being the Furd 9" axle. The "Eaton" axle that we see on our 3/4 and 1 tons also has a drop out third member, but it is a MUCH less popular axle in the world of hot rods / resto rods.
Look at a picture of the back of your axle. Match it up to ID sights on the web.
Ok, here's the skinny on the diffs (1/2 ton). The "10 bolt" and "12 bolt" diffs are the later salisbury (integrated housing) style rears (similar to a Spicer/Dana) used from '63-'87. The # of bolts refers to both the # of bolts on the ring gear and the # of bolts in the cover. The 12 bolt was used up to about '77, later on some 1/2 ton 4x4 models. The 10 bolt came in about '78, and was used in both front and rear applications. The 10 bolt is an 8 1/2" ring gear, and is considered to be about the same strength as a Dana 44. The 12 bolt is an 8 7/8" ring gear, and is considered to be in the Dana 60 range for strength.
Now your truck, if the axle is original, would have the 9 3/8" ring gear axle, with the drop out 3rd memeber. It was manufactured by Detroit gear and Axle (Eaton). There's not much being made for it as far as gears and hard parts, but bearings and seals are easy to get, and there is a 3.38 gear set being made. I think that maybe the std 3'90 gears are available too, but not 100% sure on that. You should be able to get any parts you need for it from the flaps.
Bill Burmeister
Great response. Thanks
