3 members (Hotrod Lincoln, baldeagle, Lightholder's Dad), 42 guests, and 5 robots.
Topics128,018
Posts1,055,339
Members48,419
#330697 10/30/2007 9:46 PM
I'm trying to determine if the Engine is original to the truck or not for titleing purposes.
the number stamped on the ledge behind the distributor is T1 29164 and the casting number on the block is 3835253. it appears to be a 216 CI, 2 bolts through the valve cover and tall push rod cover.
The casting number in the block leads me, depending on the source I check, to say it is possibly the original engine. I just can't find anyway to decipher the stamped number behind the distributor.
Thanks in Advance
Gary Miller
Gary,
Kelly, and Family
CenTex 52 Chevy #330751 10/31/2007 12:15 AM
The block casting number looks to be a 1948 or 1948 216 engine.
tclederman #331157 10/31/2007 7:50 PM
that rule out the engine being original. Looks like I go the bonded title route.
Gary,
Kelly, and Family
