5 members (jasrking, baldeagle, 2-Ton, Stovebolt48, 1 invisible), 83 guests, and 1 robot.
Topics128,014
Posts1,055,332
Members48,419
#33102 07/23/2003 7:47 AM
Looking at an engine has numbers 5845368 on the stater side up front? But can't find any engine to fit this number. It should be a 261 chev but can't be sure. Please help
#33103 07/23/2003 2:04 PM
Ok conductor I am going to take a stab at this and I am sure if I am wrong one of the many guru's here will correct me. If you actually have a 261 you should have a set of Captain bars "II" cast into the block ( I believe on the drivers side down near the back). Also the oil lines should be 3/4" pipe thread ( yes this is big). There may be additional ways to id this engine but these are the only ways I know without tearing into the engine itself. Good luck and I am sure someone will post the link to Jim Carter's page about 261's if not go to the link section and search his site.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#33104 07/23/2003 5:56 PM
Also post the head casting number, that should help. My '62 261 has a head casting number of 3836850. Since you are in Canada, it is likely a Canadian Pontiac 261. US Chevy 261's have full flow oil filtration with 1/2" NPT oil lines to and from the block, but I don't think Canadian ones have this feature.
Paint & Body Shop moderator
#33105 07/23/2003 11:57 PM
http://www.oldchevytrucks.com/cgi-bin/htmlos.cgi/00657.2.6677316170015882229
The 1958-1962 261 truck engines had the larger holes for the the oil filter lines (1/2 NPT which looks a lot like 3/4 holes).
Most 261s had "captain bars" but this is not a "perfect" ID. Check the link above.
Tim
