2 members (Otto Skorzeny, 5 Window 9434), 130 guests, and 4 robots.
Topics128,266
Posts1,058,385
Members48,485
#33093 05/15/2003 4:39 AM
Apprentice
Apprentice
Okay, here's the project: I want install disk brakes and pwr steering in my '47 AD One Ton. As I understand it they don't make kits for 1 tons, but there are plenty for 1/2 tons. Question: Can I pull the front end off a '42 1/2 ton that I know of, fit it with a brakes and pwr steering kit, and swap it with existing 1 Ton front end?
Are '42 front ends compatable with '47+ AD front ends?
Any help appreciated.
Thanks, Dave
Don't read the directions, that'd be too easy.
#33094 05/15/2003 6:25 AM
Dave-dunno about the exchangeability of the '42 front axle. This swap is the way to go for getting them discs and power steering under the nose of your truck, though. Just use a similar year half ton I beam, it'll bolt right onto your one ton springs. Then presto-bingo you just buy the necessary kits and you're off to the races. cool
Regarding that '42 axle, hopefully someone a little more savvy than me will chime in and let you know for sure. Best of luck with your project.
Regards,
Wannabe smile
"Don't expect anything and you'll never be disappointed"
