1 members (Paul Mullen),
99
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 5 New Guy | | New Guy Joined: Oct 2007 Posts: 5 | Hello, I am new to this forum, but long time vistor of this site. I have a 1971 chevy C-10 pickup with the 402 V8 big block. It has the original starter and alternator, but hey need to be rebuilt. Can anyone tell me of a parts company that sells a rebuild kit or at least the parts I need to rebuild both parts?? Thanks. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Welcome aboard! You should be able to get all of the parts from the flaps (freinldy local parts store), Napa would be a good place to start, or if you have locally owned place that's been around for a while, they might have them, too. Advance, O'Reillys, and Zone might be able to get them, but they will probably try to sell you a whole new/rebuilt unit. One thing I can say about napa, if you use them, is that if you get the Napa/Echlin regular for the alternator, you will be pleased with the performance. The Echlin regulators are using the same technology used in the newer GM cars, much more accurate then the originals. I swapped out the regulator in the alternator in mine for one. Made a huge difference.
Bill Burmeister | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | ShadeTree71,
Welcome to the Stovebolt...the "new" Stovebolt! You will probably be able to buy many of the parts, but they won't be packaged as a 'kit' per se. I would assume you want to do these chores yourself because you enjoy working on mechanical things, and you want to save some loot.
There are probably some procedures that would be required on the starter that are beyond just replacement. If the commutator needs to be turned and mica needs undercutting, you would need the tools and skills to accomplish these tasks.
The alternator might need bearings and brushes...I'm not sure the brushes would be on the shelf at a FLAPS.
Doing these things for the enjoyment is the name of the game, but buying factory rebuilt items might get you a better product in the long run. Whatever you decide, good luck and welcome to the garage.
Stuart
| | | | | Joined: Jan 2007 Posts: 63 New Guy | | New Guy Joined: Jan 2007 Posts: 63 | Replaced the alternator on my '67 c-50 w/ an alternator that has an internal voltage regulator in it. If the internal volt reg goes south, replacing it will be easy too. If you go that route you'll need to modify the wiring a bit, as you can't run through 2 voltage regulators. Either way you chose, it's a good idea to bring your old alternator with you when you go purchase a new one. You may find the replacement alternators don't have the same pulley as yours. This was the case with mine (duel belt pulley). The guy just pulled off my old pulley & zipped it onto the new alt. If you have a pulley that's difficult to find a replacement, you don't want it damaged, so it's a good idea to go to a place that specializes in doing starters & alternators. That's what I did, with no regrets. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Rebuilding your own units is a great choice. I,ve been doing my own GM,s for many years. Like the guys say the parts are readily available from a parts store. The quality is often better then what you get in a reman. The parts like brushes & diods on the older alt,s with external regs. are getting a little spotty. Some can,t supply them anymore. The brgs. are all the same. There are some rebuild kits for starters but you don,t need them. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There are some rebuild kits for starters but you don,t need them. I'll agree with that. maybe a new set of brushes and the end plate bushings to freshen it up. That's all I did to mine.
Bill Burmeister | | | | | Joined: Oct 2007 Posts: 5 New Guy | | New Guy Joined: Oct 2007 Posts: 5 | Thanks for posting your ideas. This is very helpful. | | |
