0 members (),
297
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 4 New Guy | | New Guy Joined: Oct 2007 Posts: 4 | I've been reading through the forums and i can't seem to find the answer to my questions. I have a 64 3/4 ton that i am about to begin to restore. Along with restoring i am also going to upgrade some parts. I want to convert the brakes to 5 lug disc brakes. i have read that the whole front end (spindle to spindle)from a 73-late 80's chevy PU bolts up directly to the truck with very few new wholes to drill. In doing the front switch, i also have to switch the rearend and i was told on another forum that the 71-72 rear end will bolt directly on to my 64, but what about the front end from that same year?
So, will the rear end from a 73 or newer truck also bolt up directly to my 64 like the front suspension? or do i have to modify anything?
or will the front suspension from a 71-72 bolt up to the truck like the rear end? Any advice or input will be greatly appreciated. | | | | | Joined: Oct 2007 Posts: 4 New Guy | | New Guy Joined: Oct 2007 Posts: 4 | Yeah, thats baiscally what i wan to do. But i need to know what years will transfer parts, that way i can just look for a donor truck. Does any one know? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Coil or leaf in the rear?
Bill Burmeister | | | | | Joined: Oct 2007 Posts: 15 New Guy | | New Guy Joined: Oct 2007 Posts: 15 | Hey, I hope you don't mind if I listen in here. I've got a '64 3/4 ton that I want to change the rear axle ratio on. right now the truck is screamin' at 55 mph; I'd like to go to a 3.56 or lower (numerically). I've heard that there's a good selection of ratios after '74 or so, but I don't know what all I'd have to change out to change the axle.
1964 C20 Fleetside Granny 4 speed 350 "Factory" air
| | | | | Joined: Oct 2007 Posts: 4 New Guy | | New Guy Joined: Oct 2007 Posts: 4 | It has coils springs in the rear. i know the 71-72 rear transfers to my 64, but will the 71-72 front suspension also directly bolt on? | | | | | Joined: Mar 2007 Posts: 34 New Guy | | New Guy Joined: Mar 2007 Posts: 34 | Transplanting any 1973-later rear axle from a 1/2 ton truck will require a little bit of fabricating. The 1973-later trucks use leaf spring rear suspensions with no panhard bar. 1963-72 1/2 ton trucks use virtually the same axle set ups. So, these would be a slam dunk bolt in, other than the correct length panhard bar. 1965-72 used the same length panhard bar, 1963-64 used a longer panhard bar, and 1960-62 used a slightly longer panhard bar. To transplant a 1973-later rear axle requires changing the axle tube spring pads, and aquiring a panahard bar relocating kit. Or, if you are really skilled with the plasma cutter and welder, which I am not, you can cut the panhard bar mounting brackets from the 1963-64 rear axle and weld it to your donor axle. This is not possible with 1965-72 rear axles, as the panhard bar mounting point is cast into the differential housing.
Good Luck!
| | | | | Joined: Mar 2007 Posts: 34 New Guy | | New Guy Joined: Mar 2007 Posts: 34 | Oops, brain fart. "The 1973-later trucks use leaf spring rear suspensions with no panhard bar. 1963-72 1/2 ton trucks use virtually the same axle set ups." Let me clarify. 1963-72 trucks with coil spring rear suspensions used virtually the same axle set up from 1963-72. This set up uses coil springs, long angled trailing arms, and a panhard bar.
Sorry for any confusion.
Seth K. Pyle | | | | | Joined: Oct 2007 Posts: 4 New Guy | | New Guy Joined: Oct 2007 Posts: 4 | Thanks alot 66fleetside! You clarified alot of the questions that i had. I have a couple more questions. I read a post somewhwere else where a guy tranfered a 75 suspension in to his 64 and only had to redrill a few holes for the idler arms. is it the same thing for the 71-72 suspensions? Does the 73 or later suspension transfer better than the 71-72 suspension? Thanks everyone for your help. i really appreciate it. | | |
