5 members (Hotrod Lincoln, Southerntruck, Ponchogl, cmayna, 1955 1 Series), 186 guests, and 1 robot.
Topics128,114
Posts1,056,287
Members48,439
#330140 10/29/2007 9:00 PM
At another vehicle site, a member has inquired about how to clean brake shoes that have been on an old IRWIPI that has had brake fluid leaked onto the shoes for about 3 years.
Any ideas?
"Happiness equals reality minus expectations" - Tom Magliozzi
Jim, I've asked the same question before. Once they get saturated with brake fluid or axle fluid they don't work right. Others have tried to clean them but they still tend to get "sticky" and cling to the drum. The only way to fix it is to replace. Perhaps someone will have a different perspective.
Kyle
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
Just replaced a perfectly good and new set of brake shoes on my recently acquired coupe, this weekend, because of bad axle seals and one bad brake cylinder.
Replaced the bearings and seals, the bad brake cylinder and installed brand new brake shoes.
Wish I could have just cleaned the soaked brake shoes in place, but have learned many years ago that just doesn't work.
Brake fluid makes them sticky and trans fluid makes them slide.
Remember 100% functioning brakes and steering are #1 priority on any moving vehicle.
If anything is worn with those systems - replace rather than repair.
On the road every day...
1952 Truck - 235
1948 Coupe - 261
for the SAE car so many years ago in college, we soaked them in brake cleaner, then laquer thinner, then baked at 400F for 2 hours to remove the residue as we were unable to get replacements in time for much needed test time. However it would have been faster / cheaper to buy new.
Bet that smelled good.
I was once wrenching on a '63 GM Concession truck. Some guy had put a grease zerk into the dust caps and must have pumped 8 tubes of grease into each drum. Everything was completely saturated. I mean the drums were full of grease, like oozing out the backing plate full. The truck had to go out that evening, and there was a week turnaround time on having the shoes relined. So I just laid them out on a piece of steel and took a propane torch to 'em. I was careful not to overheat them and crack the lining. As they heated up, the grease would begin to seep from the lining, and then burn up. It took about an hour, and when I was done, the shoes looked like new. It was meant to be a temporary fix, but they have held up well for about 2 years now... for what it's worth.
Your friendly neighborhood carnival mechanic,
Shane
She may not always start, and She may not always get me where Im going, but goddamnit, she will always stop.
