4 members (chevyb, 1955 1 Series, Otto Skorzeny, Hotrod Lincoln), 110 guests, and 3 robots.
Topics128,076
Posts1,056,008
Members48,433
#128786 10/27/2007 1:44 AM
I got patch panels for my lower cowl hinge pillars. One side needs inner & outer, the other side just the inner. I started with the side that is just the inner this morning.I figured probably about 3 hours to get it done. Drilled out the spot welds,cut out the old rusty panel,ground down to good metal the edges the new panel will weld to and drilled holes in the new panel to weld it to the pillar.It took about 1.5 hours. I tried to put the repro part in place and it looked sort of like the old part, but was quite a bit off.After cutting, bending, fitting & rebending, hammering & a small tantrum I got it to where I can weld the top to the floor edge & then will have to bend some more to weld it to the outer pillar. It is now ready to MIG weld tomorrow & total time - 3.5 hrs so far.
I had to keep telling myself if I had to make the patch from scratch it would take a lot longer & probably wouldn't look as good. The moral of the story is: If you get a repro part plan on extra work & time, but it is better than no part at all.
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
#128787 10/27/2007 2:09 AM
Welcome to the world of repro parts. Not all are bad but very few are perfect. Were the patch panels the same gauge as the original skins?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#128788 10/27/2007 5:04 AM
Yep, they keep selling them and you keep buying them.
#128789 10/27/2007 5:17 AM
These were actually the same gauge as original. I know reproduction parts don't fit as well as OEM but I found it better than trying to make patches from a sheet of steel & trying to form it myself.At least they were close & with a little effort they work. If someone made better parts they would be bought and the cheap stuff would have to get better or go under.Right now no one makes anything better.If everyone stopped buying what we can get then no one would make anything.
#128790 10/27/2007 5:30 AM
On repro parts I bought a set of cab mounts and the bolt head would slide right through the hole in the dished washer used on the front mounts.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Sorry to jack the thread, however who has the best reproduction parts as far as floor panels, kick panels and cowl panels?
Scott
I think most all the reproduction parts come from the same factory in China,so where ever you get them from you will probably get the same part.
howdy all.. I am not trying to sale parts but if you want to spend you money on parts US made, buy from Tabco Body parts..
http://www.tabcobodyparts.com/
You will get good quality stuff if they have what you need. I got some cab corners from "Classic Parts" and they were not big enough. I was pretty frustrated thinking I would have to fab something. One of the guys on the StoveBolt turned me on to TabCo. I call and spoke with a nice lady that hooked me right up. All of the parts I have gotten from the so far I have been real happy with. AND... the thought that they are made in the US makes me feel better about buying them. Buying parts from a source that is made in the US might keep your next door neighbor in a job. Just think, he might return the favor....
Jesus is Lord!
Only through the blood of Jesus are you washed clean of your sins.
Come see us... Dad's Chevy
Our Video
God bless you! Michael..
Ex Hall Monitor
Ex Hall Monitor
Depending on the year you're looking for EMS has quality, heavy gauge, USA made patch panels. They make them themselves.
Tiny #330380 10/30/2007 4:13 AM
Bitchin Products sells some very good patch panels.
http://www.bitchinproductsinc.com/product.htm
~Jim
