0 members (),
129
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | relocated my gas tank on my 49 to under the bed now to plug the hole.does any one make a patch panel for the gas filler hole i"ve seen them for other trucks but not ad's.any help .......dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | I just cut out a patch from some extra metal I had and bent it to the contour I needed. | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I did the same as Houston! | | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | Ditto here. Cut a patch from left over rear cab corner patch on my buddy's '54 3100 and it already had the perfect contour. Just welded it in and it came out perfect. With a little grinding and minimal body filler and primer, looks like it was never there. Check out the link below. http://rides.webshots.com/photo/1377338379059704903tJquCb?vhost=rides | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Excellent photos, Ralph!! | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | looks like i'll be bendin too.thanks guys........dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
