7 members (Ponchogl, Otto Skorzeny, 39Master85, Southerntruck, 50Chevy3100, BC59, 1 invisible),
136
Mod | | | Forums66 Topics128,090 Posts1,056,345 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 140 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 140 | I pulled a small block from a 1971 Gmc a few years ago and I was wondering what the specs are. Here is the numcers I found on the motor. 38 GM 3970010 This may not be the original motor that came in the gmc. I plan on rebuilding this motor to put in my 1948 Chevy 3600 wrecker. Thanks for any help
Now boltless but looking 1951 F-1 350/350 1965 Mustang 355 glide 1971 F-100 401 fe it hates me 1972 Maverick 302 c4
| | | | | Joined: Jul 2006 Posts: 40 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 40 | Jarrod; 3970010 chevrolet blocks were used from 1960-1980 with some being 2bolt and some being 4bolt. If you have a correct year motor out of a 71 GMC, I've never seen anything but a 4bolt in a 69-72 truck. They are 350 c.i., 250 horsepower, 8.5:1 comp., 4bc. I could tell you if it was a correct year motor with the letters and numbers off of the front pad, or by the date code off the back of the motor. | | | | | Joined: Nov 2005 Posts: 140 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 140 | I'll get you those numbers this evening.
| | | | | Joined: Nov 2005 Posts: 140 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 140 | Here they are for the motor out of the GMC Vo811TYZ These are the numbers from the motor in my 63 C-10. V063oPV
| | | | | Joined: Jul 2006 Posts: 40 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 40 | Jarred; You hit me up with some dandys for numbers! There are no TYZ codes for 71, but for 70 there is a TAZ For 63, there are no PV codes, there are PG and PK codes for 292 6cyl. Check those numbers again to make sure | | | | | Joined: Nov 2005 Posts: 140 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 140 | These are not the original motors that came in these trucks.
