1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 21 Apprentice | | Apprentice Joined: Apr 2007 Posts: 21 | thinking...has anyone done an update to their truck by putting a newer style pick up bed on their truck ? if so any pictures ? i know it is not original thanks raf | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Well, not a newer style, but a guy at the Bennington, VT, show this past weekend used Trex instead of wood in his. It looked pretty good. | | | | | Joined: Jun 2007 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 120 | There is a guy who put a '96 chevy short box floor in his '52. (Not me) I am attempting to use a '77 chevy dually bed floor. I will let you know what I am up against. I will send the link of the guy who did accomplish it as soon as I find out where I put it. | | | | | Joined: Jul 2006 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 79 | ive have seen a few people swap newer beds on to older chevys and a hole load more on ebay. like s10 beds,73-87full size trucks, 80's furd ranger beds , and some unrecognizable ones.
in my opinion none of them looked good ,mostly because of body line not being close.
only reason i could see it happening was if you could get it cheap and needed a bed being the old one was damaged beyond use or missing.
but its your truck and most of the time its not what anyone else thinks. | | | | | Joined: Dec 2004 Posts: 58 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 58 | I have a '54 Chevy 1 ton that had a '91 fleetside bed on it by the previous owner with fat fenders on the outside. It was hit back in Jan. by a hit & run ruining the bed and needing to replace the rearend and rear suspension. Now I have a flatbed that I built on it. Need to update my pics. Ugly to some but very functional and houses 2 marine fuel tanks at 25 gals each. It has 8 inch airbags between the c-notch and tires good for 2800 lbs. The deck sits at 37" off the ground with 0 psi and at 48" at 140 psi. I used Angelim, it's a type of Ipe. The bed is 8 ft. long and 80" wide (4" shy of 7 ft.)
1954 custom 1-ton (1 of a kind) | | |
