2 members (JeffA, Mike B), 167 guests, and 2 robots.
Topics128,162
Posts1,056,938
Members48,458
I am in the process of building a 46 3/4 ton stakebed and turning it into a 1/2 tone pickup with a 350 sbc tied to a TH350 transmission. I've removed the 46 body from it's original frame and sandblasted and cleaned all the pieces. I still have to take the cab to the media blaster. I've sandblasted everything else, with the exception of the frame, in my shop. I will be installing air conditioning, power windshild wipers and power windows. I've taken a 1987 Chev extended cab S10 and removed the body from the frame. The extended cab means that the frame will have to be sectioned one foot.
See the link for pictures: S-10 frame for a 46 1/2 pickup
If you have any suggestions, hints, tips or critisism, please don't hesitate to let me know.
Frank smile
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now.
http://www.coxcustomcars.com/
There is a factory splice where the rear "C" channel frame fits into the front box frame. If it wouldn't put the rear kick up in the wrong place then cutting at this point and putting back together after shortening the rear rails would make the splice invisible. Haven't done a 46 or older but have done several 47-53.
Evan
Thanks coilover for your input. I really wanted to cut the frame at the most square location. Plus I wanted to have something that would strenghten the weld. So the addition of the C channel would allow me to adjust the frame lenght to accomodate the centering of the wheels in the fenders, plus give extra strenght at the weld point. To hide the extra C channel I could box the frame at that location.
Frank
Looks great, I have an 87 S10 front clip on my 46. So far everything is coming together pretty well. I put new ball joints tie rods shocks etc on it last year, only big problem I have is I mounted the engine, a chev 350 and it came out about an inch too far forward. To cure that I'm installing an electric fan or might just move it back another inch. Anuway good luck on the project and it looks great. Bob T
Junior Member
Junior Member
Hows the swap going mate,
i have a 46 and a 47 that in playing wiht , the 47 is a resto rod but the 46 is currently stripped down to bare chassis waiting for me to gte the 47 finished.
was toying with the idea about changeing the frount and rear ends.
thers a heap of pic's here if anyone is intrested - http://community.webshots.com/user/Bretto63
Kind Regards, Brett
It is going very well. I've re-installed the front and rear suspension. Next step is to construct the new bed and start adding the bed, cab, and front end on to the frame for mock up.
Thanks for posting this great info. I have a 51 on an extended cab S-10 frame, instead of a long bed S-10 frame and was wondering what to do. Thanks to your post I now know. Thanks. Please keep usn posted with your picture documentary.
Jeff
Jeff. have you put the 51 on the ext s-10 frame or are you getting ready to do the swap? I am in the planning stages of doing the same and would like to know the pitfalls BEFORE I get started with this part of the project. Any information would be of great help.
I bought the truck already on the frame. Problem is it is a extended cab,not a long bed S10 and the the frame is about 6 inches too long. I have to find out where the best location is to cut it.
The cab is mounted-anybody have a recommmended area to do the splice?
Jeff
jkane, go check out my first post in this thread and follow the link. It will show you the best place to cut the frame. I chose this location because the frame rails are straight and a piece of 5" channel will fit inside them. I just bolted the 5" channel inside the frame for right now because I want to get the body, bed and front end on the frame so that I can center the wheels in the fenders. Once I have the body mocked up, I will take it all apart and weld the frame and the 5" channel all together. It should be plenty strong that way.
Frank
PS I've had to put the 46 on the back burner. I am painting a 55 Ford (yeah, I know, it's a Ford) for a friend. He brought just the Cab, fenders, hood, running boards and bed assembly over. So when I get it painted I will get back to the REAL THING, the 46.
Hey Guys....I am new here...this is my first post as a matter of fact and I see this is an old thread, but I hope someone will have an answer none the less. I just bought a 51 1/2 ton and I just moments ago traded for a regular cab, short bed s-10. Can I use the regular bed frame or do I need to get a long bed? Also, what else can I salvage out of this truck? It is running, just a blowed rear end, but I have one of those on its way.
1 Offline
check out the h.a.m.b. website it's just about all (s-10 to ad) done there. tons of pic's.
Hey...thanks for the heads up, I actually found that page a couple hours after my post. I have my frame stripped down and will start working on the mods for the 51 body swap today.
FRANK good job and great pictures. Doing it the right way buddy.
BOBT rather than an electric fan you can move your radiator support forward with a little fabrication. I don't know how much room you need but that is a possibility.
~Jim
