3 members (Jon G, Otto Skorzeny, 1955 1 Series), 85 guests, and 2 robots.
Topics128,026
Posts1,055,399
Members48,422
#326225 09/18/2007 2:49 PM
Apprentice
Apprentice
thinking...has anyone done an update to their truck by putting a newer style pick up bed on their truck ?
if so any pictures ?
i know it is not original
thanks
raf
#326226 09/18/2007 4:52 PM
Well, not a newer style, but a guy at the Bennington, VT, show this past weekend used Trex instead of wood in his. It looked pretty good.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
#326227 10/26/2007 3:35 PM
There is a guy who put a '96 chevy short box floor in his '52. (Not me) I am attempting to use a '77 chevy dually bed floor. I will let you know what I am up against. I will send the link of the guy who did accomplish it as soon as I find out where I put it.
#326228 10/26/2007 3:38 PM
Here is the link for the photo of the guys metal bed floor.
http://ca.geocities.com/kevin32jr/boxfloor
Tangovino #329786 10/29/2007 2:47 AM
ive have seen a few people swap newer beds on to older chevys and a hole load more on ebay. like s10 beds,73-87full size trucks, 80's furd ranger beds , and some unrecognizable ones.
in my opinion none of them looked good ,mostly because of body line not being close.
only reason i could see it happening was if you could get it cheap and needed a bed being the old one was damaged beyond use or missing.
but its your truck and most of the time its not what anyone else thinks.
1955 Chevrolet 3100 2nd
1954 International Harvester R-110
My Webshots Pictures
Timxxwatson #329889 10/29/2007 7:11 AM
I have a '54 Chevy 1 ton that had a '91 fleetside bed on it by the previous owner with fat fenders on the outside. It was hit back in Jan. by a hit & run ruining the bed and needing to replace the rearend and rear suspension. Now I have a flatbed that I built on it. Need to update my pics. Ugly to some but very functional and houses 2 marine fuel tanks at 25 gals each. It has 8 inch airbags between the c-notch and tires good for 2800 lbs. The deck sits at 37" off the ground with 0 psi and at 48" at 140 psi. I used Angelim, it's a type of Ipe. The bed is 8 ft. long and 80" wide (4" shy of 7 ft.)
1954 custom 1-ton (1 of a kind)
