| | | Forums66 Topics128,089 Posts1,056,009 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#32978 08/23/2004 12:46 AM | Joined: Feb 2004 Posts: 8 Member | | Member Joined: Feb 2004 Posts: 8 | Can anyone tell me if it is much of a job to transfer all the interior wiring harness from a 72 Chevy C-10 into a 70 Chevy C-10. I have never messed with this before. I want the full gauge cluster out of the 72 for the 70. Anything I really have to watch for? Thanks for any info. Rick | | |
#32979 08/23/2004 1:18 AM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | I am guessing this is not a new harness....with that said...
Have you thought about a new harness? Some of the replacements are not too spendy. Then it would be new....in theory, no issues with it...
Not sure what you are doing with your truck, but just a thought. | | |
#32980 08/23/2004 6:49 AM | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | If all you are doing is swapping instrument clusters... I did this about 25 years ago to a 71 Camaro I had at the time (replaced the idiot light cluster with the full instrument cluster). It seems to me that it wasn't too bad a job. The clusters were the printed circuit type, so I just had to move the connectors over. The clock was new, so a new wire went to the bat term on the fuse box. Of course, the oil pressure and temp senders had to be replaced . Speedo worked fine. I may have had to run an extra wire for the tach (can't remember)
Gord 1954 1/2 ton 235 4 speed
#32981 08/24/2004 2:31 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | If you're gonna rewire the whole truck, go with an EZ-Wire kit for $165 -- See This
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
