5 members (Tstan7, Napco Mark, Gone, ShopRag, Mike Roache), 68 guests, and 5 robots.
Topics128,022
Posts1,055,353
Members48,420
what are the differences between a 55 second generation, a 56 and 57 truck, all things being equal, like all are 3100 series ?
is there a difference with tail lights, blinker lights, etc ?
i want to be able to tell them apart from each other. if you have pics, please post. every time a friend asks what year truck it is, i say 55-56-57. LOL.
same with 50-54. kind of look the same to me, although i am a beginner here...thanks in advance....
1957 Chevy 3100 1/2-Ton
Photobucket pictures
basicly side emblems are differant and 57 have the differant grille
1955 Chevrolet 3100 2nd
1954 International Harvester R-110
My Webshots Pictures
3B Offline
Hy RATRODKING and guys, the 57 also has a different hood and a shorter steering column and a dished steering wheel
Steering wheel on 55 & 56 are flat. 57 wheel outer ring is raised higher than horn cap at hub. Factory turn signal arm is straight, parallel with wheel. 57 is angled.
3B beat me to it.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
From the cowl back, '55-'59 are more or less identical body-wise ('57-'59 have a shorter steering column and the 3200/3600 have a 6" longer bed). Up front, as far as the '55-'57 is conserned, it's mainly trim and grille differences. The '55/'56 use the same grille, hood emblem is different (inverted in shape), the fender emblems are similar, but the '55 is 1 peice mounted below the body crease, the '56 is 2 peice and mounted above the crease. '57 uses the double trapezoid grille, same hood emblem as '56, and a somewhat oval shaped fender emblem, mounted in the same location as '56. '57 is also the only year that the Cameo has it's own side emblem stating "3124" instead of "3100". Another change is the steering column and wheel. The '57 has a dished wheel (used for '58 and '59 also), and has a shorter column as a result. The hubcaps are different, too, and the full passenger car wheelcovers are no longer used on the DeLuxe trucks.
Here's a pic of my '55 3200 (3100 similar)
http://rides.webshots.com/photo/2556194070092261295LXjVTH
Bill Burmeister
Forgot about the hood and the turn signal switch!
Bill Burmeister
the 57 hood is differant? i dont ever hearing that. can some one elaborate on this.
The hood has 2 bulges on the top. Similar to what the passenger car has. The optional hood rockets mount to these.
'55-'56 hood http://www.classicparts.com/prodinfo.asp?number=38-818
'57 hood http://www.classicparts.com/prodinfo.asp?number=38-819
Bill Burmeister
man, you all are experts....especially LONGBOX55..thsnks for the help.. i can tell the 55-57 cars apart, that is easy. but the trucks were killing me.....but i knew where to ask....
thx longbox , i was forgot about that i was thinking something differant.
Check out http://www.chevrolettruckservice.com/ - Full rundown of all the subtle differences plus a lot of other really good info.
[b]1957 Chevy Big Window 3100[.b]
More pix in Picasa
It ain't broke 'til you can't fix it any more.
