5 members (klhansen, 52Carl, 55shaker, Shardean, Ponchogl), 87 guests, and 3 robots.
Topics128,022
Posts1,055,352
Members48,420
#32944 06/14/2003 7:44 AM
1 Offline
Alright I have a question. I'm about do rebuild my brakes for my 50' 1/2 ton and i'm deciding whether to rebuild or replace my master cylinder.
any tips on rebuilding a master cylinder :confused: would greatly be appreciated. Also, I know somethings wrong with the brake system because the previous owner had about 3 empty containers of brake fluid under the seat. So I decided to replace everything lines, master cylinder, etc.
thanks for your help!
1950 1/2 ton 3 window
#32945 06/14/2003 9:26 AM
Sounds like you are on the right track to replace everything, there is nothing in the world like stepping on the brake pedal and it just goes to the floor eek
Are you going for bone-stock restoration or are you going to upgrade a few items like a dual master cylinder set-up?
#32946 06/14/2003 9:41 AM
Lou, unless you're planning a total restoration, a dual-circuit master is a necessary safety upgrade. My original master blew up on a downhill grade and I put it into a telephone pole to avoid pushing a Benz through a busy intersection. Sheetmetal is pricey, but cheaper than a lawsuit. If you decide to restore the stock single-stage master, make very sure that the parking brakes are capable of doing the job in a crisis.
There are many brake kits available, I chose a power-assist unit with an "offset bracket" that let me bolt it to the frame in roughly the stock location. I can't use the fill hole in the floor; the resevior is closer to the tranny cover, so I just pull out that section of the floor if I need to top it off. However, in the 3+ years since installed the new master and lines, not a drop has leaked (and no new sheetmetal purchases). grin
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#32947 06/14/2003 11:13 AM
1 Offline
right now my plans are to just get it running and poke around town once in a while.
#32948 06/14/2003 11:49 AM
If you are replacing all the lines, it is not that much more work to upgrade to a dual master cylinder..
Personally, I would never rebuild either a master or a wheel cylinder. That is one area where upgrading to new parts is money well spent..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#32949 06/14/2003 5:22 PM
1950Lou,
If the cylinder bores (walls) on wheel or master cylinders are not pitted, I rebuild (never had a problem). However, the walls are usually pitted and you usually have to replace the cylinder.
You will need a drill-driven cylinder hone (two or three stone) to rebuild a good cylinder.
Tim
#32950 06/14/2003 5:52 PM
50Lou,
If you plan on keeping your orig lines, and there is no reason not if they are in good shape, you need to clean them out. Go get yourself some drug store alcohol and a syringe of some type. Push it into the line, let it sit for awhile and blow our with air. Cover the exit side of the line to keep the clumps from going all over. Then repeat until clean. This is the best way I have found to get all the junk out.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
#32951 06/16/2003 7:55 PM
First, don't use drug store (isopropyl) alcohol. It contains water, either 10 or 30%. Use denatured alcohol, you can get it at the hardware store. I hope that's what 52 meant to say.
However, I would recommend following MetalMans advice. And if you replace all the components, lines, hoses, wheel cylinders and master cylinder, it would be a good time to go with the DOT5 brake fluid, unless you will be driving the vehicle at least every other week year round. The DOT5 fluid is silicone base and doesn't absorb water, but it also doesn't react quite as fast to the pedal pressure. Most people can't tell the difference.
And be sure the emergency brake works good. My brother-in-law put his 54 down a cliff about 100 feet when his luck ran out on his leaky brakes. eek
Fred
52 3600
69 C-10
#32952 06/16/2003 9:42 PM
Part of the problem with DOT5 is that it doesn't expand rubber, which can be necessary in some MC and wheel cylinders for leak free operation. I can't use it in my motorcycle because of that.
Paint & Body Shop moderator
#32953 06/16/2003 10:07 PM
I stopped using DOT5 for a few reasons, mostly because it is overpriced and isn't much better than DOT3.
True, it will not absorb water but water still gets into the brake system via condensation and puddles instead of being absorbed. Result, the puddles freeze in cold weather. It is also not compatible with lots of brake seals, especially older ones.
If you bleed your 3 system every couple of years to get junk out and fresh in it will last a long time and not cost a bundle.
'31 Chevy 1 1/2 ton,
'42 GMC 2 1/2 ton 6x4,
'52 GMC 2 1/2 ton 6x6,
'53 GMC 5 ton
#32954 06/16/2003 10:32 PM
I put a dual master cylinder in my GMC and filled the system with DOT 5. It took about a pint and a half. At $6.50 a pint , I am into the deal for about 10 bucks..
It will not eat paint from my newly painted frame or backing plates.. No flushing required. The pedal is as hard as in any vehicle I have ever driven..
I keep hearing the horror stories about DOT 5 but have yet to experience the horrors..
Bill M
53 GMC Hydra-Matic
Home Page
#32955 06/17/2003 5:46 PM
1 Offline
thanks for all the suggestions. When I took off one off the brake hoses the insides looked like a clogged artery.
