7 members (eclector, 32Fordpuchoptop, Hotrod Lincoln, dt235sd, MickeyP, 2 invisible), 154 guests, and 1 robot.
Topics128,033
Posts1,055,531
Members48,425
#32892 04/30/2003 5:09 AM
Recentley I rebuilt my stock steering box to my 55' chevy pickup. I'd asked the local parts guy what type of oil to service it with and he said they didn't make a regular oil for those steering boxes.He said just to use good ol differential- standard transmission 90 wt. oil, is that right? frown
#32893 04/30/2003 5:49 AM
My maintence manual calls out GM Steering Gear Lubricant so apparently they did make it. It doesn't give an SAE wt. # though. An interesting note though, it says the fill plug hole is the max level it should be filled to prevent oil from coming out your steering wheel so pour it in rather than using a pressure gun.
#32894 04/30/2003 6:38 AM
I use 90wt. gear oil in a steering box I rebuilt three years ago. No problems so far. smile
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#32895 04/30/2003 4:53 PM
GM has a manual steering box lubricant. It is not easy to get thru a dealer. The last I got had to come in from the Left Coast. Normal auto parts places do not stock when I was searching last year. I will check tonight to see if there is a PN on the squeeze bottle for you.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
#32896 04/30/2003 5:09 PM
Unfortunately, GM stopped making this product about two years ago and the only way to get it is through NOS inventory in dealerships.
It is packed four tubes per case and I got mine from another Stovebolt member who was kind enough to give me a tube. It's heavier than 90W so 90w will be too thin I think. There's a 600w gear oil out there that might work but again I don't know for sure.
I posted the part number here last year and if it didn't get purged from the history, perhaps a search will turn it up for reference.
#32897 04/30/2003 5:36 PM
American Classic Truck Parts (a major sponsor of stovebolt.com) carries it (model # SGLUBE) at $15 per 10 oz tube.
American Classic Truck Parts catalog page
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
#32898 04/30/2003 5:57 PM
I rebuilt my steering box a couple of years ago and bought some of the Chevy lube. It came in a four pack and cost about $8 a tube. It takes a little over 1 tube to fill the box. I still got two tubes.
Is it OK to say that?
Dennis
#32899 04/30/2003 6:38 PM
You can use gear lube in a tight box, but if there is any wear it will leak. Some of the older GM manuals stated that chassis grease was an acceptable substitute. I would use a moly base grease, it retains its viscosity at lower temps better than a lithium base.
Fred
52 3600
69 C-10
#32900 04/30/2003 11:54 PM
I've always made my own by mixing gear lube and grease. Seems to work OK. Any lube that doesn't run out is probably good enough as nothing in a steering box turns fast at all.
To be long remembered as he's cruising in
The Passing Lane
#32901 05/01/2003 1:57 AM
Go to an industrial lubricant dealer and get some Exxon Dynagear.It is available in small plastic tubes and is a semi-fluid,very tacky,moly fortified blackish-red grease.It's just the ticket for Ross cam and lever gears and the Saginaw gears.I have used it for years in forklifts,old construction equipment and heavy trucks,or just about anything that I have not converted to an integral gear or an Orbitrol. cool
#32902 05/01/2003 2:19 AM
I put moly open gear grease in my 57 panel when I got it cause the original stuff was all over the outside instead of inside - worked great for 12 years. cool
#32903 05/01/2003 5:39 AM
Penright makes a really good steering box lub that stay in boxes with no seal
Mine ustta run like a tourist in Mexico...
#32904 05/01/2003 6:41 AM
Boy I wan't to thank all you Bolters for your recomendations , comments etc. etc. on my topic. Thank You.. smile
#32905 05/01/2003 8:02 AM
I have used and was recomended by a mechanic is CV joint lube he said the part that are lube have a similarity. and I used it succesfully. Ed ke6bnl
1963 econoline, 50 f1 pu, maybe 53 chevy pu, 50 f3 pu, 70 chevy shortbed c10,
#32906 05/01/2003 12:50 PM
I think the GM part number of the discontinued steering lube grease is/was: 001052182 (This might be the part # from OldCarKook - I got it here but did not write down the name of the source).
Tim
#32907 05/02/2003 2:17 AM
k10 Offline
Does anyone know if a rebuild kit exists for a '61 4x4 box. I have had no luck in finding a kit. I have seen rebuilt ones and checked the links page but no dice so far. So as to not completely hijack the thread, I would surely use the aforementioned recommendations as to lube types. grin
#32908 05/02/2003 3:45 AM
John Deere makes a special gear lubricant called Corn Head Grease. The part number for a regular tube is AN 102562. It is rated NLGI grade 0. This grease is used in row unit gear boxes on corn heads. It is installed with a grease gun and is more fluid than regular gun grease. It is designed to stick to gears and lubricate pressure points and stay just thick enough to stay in the gearbox even if the seal is marginal. When I rebuild my steering box, this is the grease I will use. It is very close to the original steering gear grease.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
#32909 05/02/2003 11:08 PM
Apprentice
Apprentice
Okay, should I be lying awake at night wondering about my steering box lube? How would I know if it needed more -- steers hard? Hell, its a '47 1 ton. Keeping it in one lane is an art form. Or could that be the tires?
Don't read the directions, that'd be too easy.
#32910 05/03/2003 12:33 AM
V
V Offline
It should steer really easily unless it's dry .
There's a pipe plug on the top of it , remove and add some 90W as it's empty sure as sh*t .
I gotta try some of these newer lubes as mine runs out too , takes about 3 months to go dry so I top it every month .
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
#32911 05/03/2003 6:53 AM
Over on the Corvette restorers page there was a thread about the same thing. Came down to part number 12377985. Went down to the local GM dealear yesterday and ordered some.
Came in today and it's labeled 'Chassis Grease'. Further reading says " GMC CHASSIS GREASE is a premium grease for chassis lubrication. It is made up of a special grease consisting of oil, lithium thickening agents and special lubricants. This product is standard chassis lubrication on all GM vehicles."
Sounds like pretty 'special' stuff to me. wink wink wink
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
