3 members (Waveski, Otto Skorzeny, chuck2213), 70 guests, and 4 robots.
Topics128,021
Posts1,055,357
Members48,420
#32873 08/31/2003 2:47 AM
help does any one know if there is a univeral joint made to adapt a 85 s10 drive shaft to a 72 nova rear end carquest part # 3-3140 is very very close but alas not right this is the missing part of my 51 3100 small block and auto swap
#32874 08/31/2003 2:51 PM
I've always gone to the parts store with the dimensions and they looked in the books and found one.
Fred
52 3600
69 C-10
#32875 08/31/2003 4:04 PM
AFAIK, the 4 spider ends have to be the same diameter and the size 'across' the spide must be the same for both sides of the U-joint.
If not, you need to get a U-joint that fits the read end, and have a driveshaft shop add that end to the S-10 driveshaft.
Cheers!
George
#32876 09/01/2003 12:42 AM
Actually, there is such a thing as a "conversion joint" that will have two different diameters or widths, depending on your need. Any good driveline shop will know............Might cost you $20-$25 for one U-Joint though eek .
I had to get one when I had a '68 Chevelle w/factory 4spd. I put an M-22 in it (Saginaw 4 spds are WEAK) and they use a larger slip yoke (same as TH-400), so a conversion joint solved the problem.
Also, some F O R D's actually came stock with "goofy" U-Joints like that............typical "Blue Oval" engineering :rolleyes: :p smile
*** GMC ***
