2 members (Thomaslb, Eddie54),
166
0
Mod | | | Forums66 Topics128,080 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 143 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 143 | I just picked up a 46 1/2 ton in great condition. I'm going thru her and fixing various small items making it a good driver. One problem is that the previous owner had tied a rope between the door and window handles to keep the windows from rolling down. If I take the rope off the window will literally roll down 1/2 - 3/4 open just by the weight of the window. The door glass is loose and I can fix that with new channel. Nothing seems broken but the regulators are a bit sloppy. What's the fix for this problem? Thanks.
It never costs more to ask and it never costs more to think big.
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | You can get a kit to rebuild the regulators from most of the usual vendors. There is a coil spring in the window mechanism that holds up the window. Yours might be broken or worn out. I'm not sure if anyone makes replacements. Hope this helps. George | | |
