3 members (Bill Marlow, 2 invisible),
109
Mod | | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#32803 04/03/2005 3:12 AM | Joined: Dec 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 127 | i have a 1954 chevy 1/2 ton. it has a 235 straight six. i just added a dual intake manifold with two rochestor one barrels. whenever i hit the gas while im driving, it sounds like it is going to flood out!! what should i do to adjust this? and also it doesnt seem to have the same ooomph as my original intake with a 1BBL carb. and i dont know if my carbs just need adjusted. when i am doing about 35 it seems as if when i hit the gas that it doesnt have much more power it just slowly speeds up? any help would be great!! thanks | | |
#32804 04/03/2005 3:45 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | old54truckluvr,
There are a lot of people who frequent this site who have a dual carb 216/236/261. Post a little more information and I bet there will be many opinions.
What kind of intake manifold?
How are you heating the intake manifold? How?
Are you sure the "choke flaps" are open in both carburetors? How have you set up the choke (is only one carb choked - by cable ?)?
Did you rebuild both carburetors? Are both accelerator pumps new (and squirting gas)?
Tim | | |
#32805 04/03/2005 10:41 PM | Joined: Dec 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 127 | i have an edelbrock intake. i am sure the choke flaps are open and only one carb is choked. the carburetors have been rebuilt and i dont know about the accelerator pumps but they seem to work. i am not heating the intake manifold. thanks | | |
#32806 04/04/2005 5:17 PM | Joined: Jan 2005 Posts: 95 Member | | Member Joined: Jan 2005 Posts: 95 | It sounds like your accelerator pumps aren't working. Redcoat | | |
#32807 04/04/2005 7:52 PM | Joined: Apr 2005 Posts: 1 Junior Member | | Junior Member Joined: Apr 2005 Posts: 1 | First, are the basics good?
Are both mixture screws about 1.5 turns out?
Is the linkage adjusted so both butterflies are opening and closing together?
How's the idle once they are warmed up?
Any intake vacuum leaks?
I would doubt both accelerator pumps would be bad on rebuilt carbs - I'm thinking it's probably a combo of adjustment problems. | | |
#32808 04/04/2005 10:16 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Both carbs need chokes otherwise your only putting the richer mixture to half the engine. The old Chevies were and still are cold natured engines. Next thing, and it seems to be pretty critical on the dual carbs, is to use the heated intake. The kits are available from Langdon. | | |
#32809 04/05/2005 2:13 AM | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | Where did you get the rebuilt carbs? Mine were Holly rebuilds with neoprene pumps. Neither one of them pumped anything. NAPA sells the correct leather pumps for the Rochester. | | |
#32810 04/05/2005 3:26 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I think you have a power valve problem. You need to modify it so that the part/full throttle mixture is correct. See http://www.inliners.org/tech/tech4.html
#32811 04/06/2005 4:46 PM | Joined: Jul 2000 Posts: 53 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 53 | My setup works well choking only one carb. What size air filter do you use? I took someone's advice on this board and dumped the little donut filters that you normally see on these setups. I got much taller filters, and it make a HUGE difference! How did all this sawdust get under the hood? | | |
#32812 04/07/2005 4:18 PM | Joined: Dec 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 127 | i have just small air filters that aerent very big at all. but bigger ones will make a big difference, maybee i will try that! | | |
#32813 04/07/2005 4:51 PM | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | I had a similar problems with 2 1bbl Rochesters on an Offy dual intakeon a '58 235...solution was 2 fold...(1) check fuel pressure...I was getting way too much, put in a NAPA fuel pressure regulator and the "loading up" stopped right away.2)But, bottomline, 2 1bbl Rochesters are way too much caburetion for that 235...Ultimately had to get rid of the Rochesters...couldn't stand the smell of leaking gas and the ugly look of stained carbs, plus the MPG stunk...switched to 2 1 bbl Carters and haven't had a problem since...no leaks,smells and better MPG. | | |
#32814 04/07/2005 4:53 PM | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | By the way, set fuel pressure between 3.5 and 5 lbs...depending on what works for your situation. | | |
#32815 04/12/2005 7:47 PM | Joined: Dec 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 127 | where can i find 1bbl carters at, and how much do they cost? thanks | | |
