2 members (Hotrod Lincoln, greenie-reddy), 96 guests, and 2 robots.
Topics128,049
Posts1,055,741
#328055 09/24/2007 3:00 AM
What goes on the door check [I think that is what it is called ] where it stops the door from opening to far. On my 1940 all I found was a chunk of rubber and a rubber bushing from what looked like a shock absorber. This obviously was not original, but I did find a split piece of 1 1/2" wood dowell with a hole in it in the bottom of the kick panel area. What is the best thing to use?
Brian
#328056 09/24/2007 5:46 AM
There is a configured chunck of rubber that is attached to the door check in a manner so as to allow the rubber to be slightly compressed just before the door is completley open and when the door is completely open. That rubber is kind of like a spring, if you will that "sets" the door in it's open position. The shock piece of rubber is something someone just rigged up. The piece of wood has nothing to do with the door check.
I believe those door checks are reproduced. You can probably find them available from several of the vendors.
Joe smile
