5 members (1955 1 Series, TUTS 59, bluechev, Guitplayer, 1 invisible), 101 guests, and 1 robot.
Topics128,030
Posts1,055,418
Members48,422
#328016 09/10/2007 9:35 PM
My driver side regulator has some stripped out teeth travel gear (large half gear. I found some others in decent condition but have some worn teeth. Has anyone worked out a good solution to restoring the teeth?
Thanks for any help.
#328017 09/12/2007 3:52 AM
Junior Member
Junior Member
If you cannot find decent ones maybe a welder and file and one tooth at a time??????????
#328018 09/13/2007 9:43 PM
Yep, thought of that one myself.
Also, having a new plate cut at a machine shop and then hardening them to prevent the same thing.
Thanks.
I'm kinda leary about busting them apart, but it will likely take that to do it right.
