| | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 2 New Guy | | New Guy Joined: Jul 2007 Posts: 2 | My driver side regulator has some stripped out teeth travel gear (large half gear. I found some others in decent condition but have some worn teeth. Has anyone worked out a good solution to restoring the teeth?
Thanks for any help. | | | | | Joined: Apr 2002 Posts: 16 Junior Member | | Junior Member Joined: Apr 2002 Posts: 16 | If you cannot find decent ones maybe a welder and file and one tooth at a time?????????? | | | | | Joined: Jul 2007 Posts: 2 New Guy | | New Guy Joined: Jul 2007 Posts: 2 | Yep, thought of that one myself. Also, having a new plate cut at a machine shop and then hardening them to prevent the same thing.
Thanks.
I'm kinda leary about busting them apart, but it will likely take that to do it right. | | |
