0 members (), 254 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#327972 08/07/2007 3:19 PM
Just read that the doors for a '72 C-10 are different from '67-71 (no further details given, just "different"). Is this true, and if so what's the difference? It would suck if I'm limited to searching for new doors that are specific to a single year. :-(
Brent
yeppers, they are different. The door panel used on 72 is a formed plastic, earlier ones were metal. So, the window crank & door handle stick out farther & the panel secure w/clips instead of screws. Also a screw was added just below the vent window to hold the inner & outer door panels together.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Thanks for the great info. Looks like Chevy screws me again!
Quote
Originally posted by TooMany2count:
Quote
Originally posted by 64fleetside:
[b] yeppers, they are different. The door panel used on 72 is a formed plastic, earlier ones were metal. So, the window crank & door handle stick out farther & the panel secure w/clips instead of screws. Also a screw was added just below the vent window to hold the inner & outer door panels together.
BUT will they fit & work on an earlier truck???? [/b]
Oh yeah, they interchange
Now I'm more confused than before. They interchange but they're different? Whaaa? Will the '72 door panels work on an earlier door? I don't want to get into mixing and matching interior parts from different years. Not looking for a concourse restoration -- just simplicity for my own mental health. :-)
The doors will swap from truck to truck but won't be "correct", the panels won't interchange between doors w/o mods & swapping the window regualtors & door controls.
Thanks for the clarification. Guess for now I'll stick to looking for a decent pair of '72 doors to keep things simple.
