| | | Forums66 Topics128,091 Posts1,056,038 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | Just read that the doors for a '72 C-10 are different from '67-71 (no further details given, just "different"). Is this true, and if so what's the difference? It would suck if I'm limited to searching for new doors that are specific to a single year. :-(
Thanks, Brent | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | yeppers, they are different. The door panel used on 72 is a formed plastic, earlier ones were metal. So, the window crank & door handle stick out farther & the panel secure w/clips instead of screws. Also a screw was added just below the vent window to hold the inner & outer door panels together. | | | | | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | Thanks for the great info. Looks like Chevy screws me again! | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Originally posted by TooMany2count: Originally posted by 64fleetside: [b] yeppers, they are different. The door panel used on 72 is a formed plastic, earlier ones were metal. So, the window crank & door handle stick out farther & the panel secure w/clips instead of screws. Also a screw was added just below the vent window to hold the inner & outer door panels together. BUT will they fit & work on an earlier truck???? [/b]Oh yeah, they interchange | | | | | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | Now I'm more confused than before. They interchange but they're different? Whaaa? Will the '72 door panels work on an earlier door? I don't want to get into mixing and matching interior parts from different years. Not looking for a concourse restoration -- just simplicity for my own mental health. :-) | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | The doors will swap from truck to truck but won't be "correct", the panels won't interchange between doors w/o mods & swapping the window regualtors & door controls. | | | | | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | Thanks for the clarification. Guess for now I'll stick to looking for a decent pair of '72 doors to keep things simple. | | |
