1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#32785 03/18/2002 8:42 PM | Joined: Jun 2001 Posts: 34 Member | | Member Joined: Jun 2001 Posts: 34 | I am getting s9ome pr9onu 9ounced
I am getting what seems to me to be a lot of body roll when cornering in my 53 ton panel truck. I'm thinking that an anti- sway bar would help tighten the suspension. (The springs seem ok and I replaced the shackles, bushings and pins) The center to center distance of the frame rails above the front axle is about 24". Can anyone suggest a source for a good new anti-sway bar or better yet, maybe, a donor truck to pull a bar off of?
Also, anyone else having trouble searching for old topics or is it just me and my antiquated 'puter? Thanks, Don. | | |
#32786 03/18/2002 10:08 PM | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | Paneltruck I had a 55 1st series burb that had a sway bar on it that was stock. It did not help much, I have done the off ramp two wheel thing at 35 mph,  very top heavy tward rear I thought about a rear restricter strap like on old 544 volvos. | | |
#32787 03/18/2002 11:56 PM | Joined: Jun 2001 Posts: 34 Member | | Member Joined: Jun 2001 Posts: 34 | T-ruck: Haven't had that experience yet, doesn't sound good. Would still like to hear more opinions. Also, don't need the names of parts sources ,will check the links. I would like to hear about a scrapyard match though. | | |
