5 members (Jon G, dt235sd, 1955 1 Series, Otto Skorzeny, 1 invisible), 100 guests, and 0 robots.
Topics128,049
Posts1,055,689
#32785 03/18/2002 8:42 PM
I am getting s9ome pr9onu
9ounced
I am getting what seems to me to be a lot of body roll when cornering in my 53 ton panel truck. I'm thinking that an anti- sway bar would help tighten the suspension. (The springs seem ok and I replaced the shackles, bushings and pins) The center to center distance of the frame rails above the front axle is about 24".
Can anyone suggest a source for a good new anti-sway bar or better yet, maybe, a donor truck to pull a bar off of?
Also, anyone else having trouble searching for old topics or is it just me and my antiquated 'puter? Thanks, Don.
#32786 03/18/2002 10:08 PM
Paneltruck
I had a 55 1st series burb that had a sway bar on it that was stock. It did not help much, I have done the off ramp two wheel thing at 35 mph, eek very top heavy tward rear I thought about a rear restricter strap like on old 544 volvos.
#32787 03/18/2002 11:56 PM
T-ruck:
Haven't had that experience yet, doesn't sound good. Would still like to hear more opinions.
Also, don't need the names of parts sources ,will check the links. I would like to hear about a scrapyard match though.
