My window regulator on the driver's side door in my 1972 1/2 ton pickup went kaput, so I have a new one from LMC. However, I can't get the old one out. The forward window track sits directly outboard of the regulator so there is not enough room to get the window crank drive shaft out of the panel hole. I losened the track but it will not give enough to let me get the regulator out of the hole. ohwell
Does anyone have a 'how to' on the replacement of the window regulator for this truck? I could sure use the help!
Thanks!
Bolter Rush, Cave Springs, AR
1954 Chevrolet 4400 Flat Bed Dump, 1972 Chevrolet long bed.
Email: mikeshahan1960@gmail.com
