0 members (), 46 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#327664 12/27/2006 5:57 PM
Trying to get the cab apart for resto.
On the driver's door, lower hinge, one of the nuts on the mounting bolt is spinning free. So I thought I'd slide the door off the hinge, then fight with the hinge without the weight of the door. I undid all of the lower bolts, but the door isn't sliding off the hinge. I didn't want to force it if it wasn't supposed to go. Am I missing a step?
Thanks, mark.
51 KY 3100
#327665 12/27/2006 8:48 PM
I
I Offline
i dont see you missing any steps. Theres three bolts in the door hinges, at the door. It wont just fall off, you'll have to pull fairly hard to get it off. It common for the hinge bolts to do this in the A pilars. The nut is only spot welded on. Ussally you have to cut the bolt head off with a die grinder to get it apart. Fixing the trouble is a whole lot harder, as you have to weld a nut back on. If you have cowl panel damage to fix, thats the time to work on the hinge pockets. Alway tap out the holes (3/8 fine) before installing the door parts.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#327666 12/29/2006 3:28 PM
Sometimes you have to tilt the door out from the top since the hinge is made with a slight bend. Try that and see if it works. Thats what I had to do.
