2 members (VicZ, doyle1950),
143
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 6 Junior Member | | Junior Member Joined: Jun 2006 Posts: 6 | Hello. I have a 51 and I'm attempting to rebuild my doors. I bought the glass, some used regulators, and vent windows. My question is if anyone knows of a vendor who sells the lower frame that the window rides on? In the manual it looks like there is a channel attaches to the regulator, and the window glass rides on it. I have checked all around and I am hoping its not one of the parts I need to find used. Thanks for any help you guys can give. Corey | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Corey, I see your not getting any response. Like a lot of the guys here, I very rarely look at the clinics, spend 99% of my time surfin’ the V’ Garage. Take a look at the pics below and if your talkin’ bout the cad plated ‘C’ channel in the upper portion of the picture I’m afraid your out of luck. That’s not being reproduced as far as I know, so you’re going to have to look for them used. http://rides.webshots.com/photo/2566710950098611668bcnMYR Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | may wanna check with Jimbo59 here, he has alot of used parts, pretty cheap, sells on ebay often. Mike | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | if you need one or two,,,i have em. 20.00 ea. plus shipping from 94553. just to be sure,,thats doors WITH wing windows,,right? Thanks,Marty | | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | denny .pics of the regulator are great i was hopeing someone would have some shots or drawings of the window channels .i have decided to go ahead and make my 54 doors into single glass style without the vent.any help would be appeicated thanks len.
layback
| | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | some on ebay now, item number 76323868 seller is 47prostreet, Mike | | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | have tryed the ebay no. no luck with that no.
layback
| | | | | Joined: Jan 2004 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2004 Posts: 70 | The ones on ebay are for windows without vents, I think | | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | i have aquired the regulator. from ebay .now all i need is the inside the door channel from the 49/50 door.that would be the metal part that holds the felt channel.with a bit of cuting and fooling around i will have myself doors with full size glass with push botton handles . any comments or anything that might help..... anything i am overlooking.thanks len.
layback
| | | | | Joined: Dec 2006 Posts: 37 Member | | Member Joined: Dec 2006 Posts: 37 | LB, LMC catalog has them now, | | |
