6 members (1955 1 Series, walter74, artinva, Wally / Montana, SNOYL, Hotrod Lincoln), 59 guests, and 1 robot.
Topics128,078
Posts1,055,936
Members48,430
#327635 12/04/2006 4:53 AM
Junior Member
Junior Member
Hello. I have a 51 and I'm attempting to rebuild my doors. I bought the glass, some used regulators, and vent windows. My question is if anyone knows of a vendor who sells the lower frame that the window rides on? In the manual it looks like there is a channel attaches to the regulator, and the window glass rides on it. I have checked all around and I am hoping its not one of the parts I need to find used. Thanks for any help you guys can give.
Corey
#327636 12/19/2006 4:00 PM
Corey,
I see your not getting any response. Like a lot of the guys here, I very rarely look at the clinics, spend 99% of my time surfin’ the V’ Garage.
Take a look at the pics below and if your talkin’ bout the cad plated ‘C’ channel in the upper portion of the picture I’m afraid your out of luck. That’s not being reproduced as far as I know, so you’re going to have to look for them used.
http://rides.webshots.com/photo/2566710950098611668bcnMYR
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#327637 12/19/2006 4:50 PM
may wanna check with Jimbo59 here, he has alot of used parts, pretty cheap, sells on ebay often. Mike
#327638 12/20/2006 5:05 AM
if you need one or two,,,i have em. 20.00 ea. plus shipping from 94553.
just to be sure,,thats doors WITH wing windows,,right?
Thanks,Marty
#327639 01/20/2007 4:19 PM
denny .pics of the regulator are great i was hopeing someone would have some shots or drawings of the window channels .i have decided to go ahead and make my 54 doors into single glass style without the vent.any help would be appeicated thanks len.
layback
#327640 01/21/2007 6:10 AM
some on ebay now, item number 76323868 seller is 47prostreet, Mike
#327641 01/22/2007 10:05 PM
have tryed the ebay no. no luck with that no.
layback
#327642 01/22/2007 10:55 PM
The ones on ebay are for windows without vents, I think
#327643 02/01/2007 12:31 PM
i have aquired the regulator. from ebay .now all i need is the inside the door channel from the 49/50 door.that would be the metal part that holds the felt channel.with a bit of cuting and fooling around i will have myself doors with full size glass with push botton handles . any comments or anything that might help..... anything i am overlooking.thanks len.
layback
#327644 02/03/2007 7:49 PM
LB, LMC catalog has them now,
