| | | Forums66 Topics128,264 Posts1,058,355 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 73 Member | | Member Joined: Jun 2004 Posts: 73 | I have a 51 so obviously I have the wing windows , but they arent as solid as I wanted to start with so I bought a set of 50's., without the vent. Question is: Will everything else change over from the 50 to the 51 including window frames or is everything different? Thanks. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | The 1950 doors should fit the same. I am not sure of the door latch mechanism. I know my 54 had a different latch mechanism but since your 51 had the pull down handles as the 1950 does you should have no problems. | | |
