| | | Forums66 Topics128,052 Posts1,055,738 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 43 Member | | Member Joined: Jan 2006 Posts: 43 | im trying to install these carboard door panenls on my truck with no luck.i got them from cd and they where cheap so i wasn"t expecting much but the problem is with the door handle it pushes them out rite above the handle it seems the flat bar from the handle to the door lacth should be flipped over so it goes into the indention but it wont work that way.anyone with a picture maybe. thanks | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | Mine's the same way. It bows out from the hardware and there is no other way to mount the hardware. I put a little bend in the SS frame so it hugs the door on the perimeter. Just the way it is, I reckon. | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | The original door panel frames were "kinked" to follow the contour of the door.
Bob | | | | | Joined: Jun 2006 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 49 | Bobhas it right. You need to bend the frame to match the door shape. It is also important that you put the "spacers" under the panel. There are two. Both rectangular in shape. They are about a half inch wide, maybe 2 inches long, and about a 1/" thick. One is glued (use 3m adhesive) just above the triangular piece of the remote control arm. The other goes vertically at the latch side of the long hole. These keep the remote control arm from rubbing against the cardboard. BTW, if you spray the back of the cardboard with clear coat or even paint, it'll withstand humidity a lot better. | | |
