0 members (),
160
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | hey guys. thinking of putting in power windows. my regulators/rollers are shot and from what i have found a power kit is about the same price as redoing the original. has anyone done this on a 63 and retained the vent windows? if so chime in and let em know how it went. i am contempllating purchasing a flat glass kit off ebay for about $150 shipped | | | | | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Troy, Power windows can be installed with some work, but you will have to keep the vent window in order to use them.
There is a guy that has a '62 that has them, and he loves them. He mounted the switches under the dash.
Me I would use the switch that uses the window crank handles, and uses the existing hole. I have only seen the 1 piece window kits for the '64-66 trucks only.
I've been trying to figure out how to run 1 piece windows on a wrap around '60-'63 cabs without chopping the top, due to the "A" pillar's angle.
I've came up with some import rear windows that will "twist" the glass inthe door as it goes down missing the "A" pillar all together. But a tri-5 chevy rear window regulator should work, it works the same. David
My truck don't leak oil, it just marks its teritory.
| | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | Thansk for the response. i want to keep the vent windows, no need to buy new glass, plus im on a budget. im assuming you would just swap out the old manual regulator for the new power one and wire it up. i assume you would still use the old side tracks and everything. still not sure what i would want to do for switches... right now the window crank always hits my knee so i may do away with them and go somewhere else with my switches... we'll see. | | |
