4 members (CuzzFuzz, baldeagle, Ponchogl, Stovebolt48), 68 guests, and 6 robots.
Topics128,021
Posts1,055,346
Members48,420
#327421 04/28/2006 9:33 PM
I just ordered a door glass guide that my truck was missing. This is the part that guides the window at the lower end of its run, and it screws into the door with 2 screws about midway down the door.
Has anyone put this in? Is there any magic to it, and can I use just any sheet metal screws?
Thanks in advance.
#327422 04/29/2006 3:53 PM
What year?
If it's AD, there's no tricks, any sheetmetal screw of the correct size will work but try to find a tapered head type. There is also a screw that goes in at the top as well.
wilbur
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#327423 04/30/2006 3:39 PM
Wilbur,
Its a '54. Where does the top screw go?
#327424 04/30/2006 6:42 PM
There should be 2 slots at the top, the screw goes in the top one.
#327425 05/01/2006 6:42 PM
Thanks. I just got the parts I ordered, except the glass guide is on back order so I can't look at it. I may be hounding you down the road when I get it.
Thanks for the help.
