2 members (Gdads51, WICruiser),
84
Mod | | | Forums66 Topics128,268 Posts1,058,319 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | I just ordered a door glass guide that my truck was missing. This is the part that guides the window at the lower end of its run, and it screws into the door with 2 screws about midway down the door.
Has anyone put this in? Is there any magic to it, and can I use just any sheet metal screws?
Thanks in advance. | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | What year? If it's AD, there's no tricks, any sheetmetal screw of the correct size will work but try to find a tapered head type. There is also a screw that goes in at the top as well.
wilbur | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Wilbur, Its a '54. Where does the top screw go? | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | There should be 2 slots at the top, the screw goes in the top one. | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Thanks. I just got the parts I ordered, except the glass guide is on back order so I can't look at it. I may be hounding you down the road when I get it.
Thanks for the help. | | |
