Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (Phak1), 91 guests, and 2 robots.
Topics128,274
Posts1,058,433
Members48,490
#327363 02/22/2006 5:36 PM
closes but will nor latch striker pin is there door mecanism works what the@#%*@ on a 62 carry all
bill
#327364 03/03/2006 8:51 PM
Junior Member
Junior Member
it would be easier to answer your questions if they were a bit descriptive.... your door closes, but will not latch? Have you tried lubing the mechanism? does it move? is it siezed?
#327365 03/03/2006 9:11 PM
you need to remove latch from door & clean/lubricate it well,,I usually soak in carb cleaner then oil w/30w. brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
