| | | Forums66 Topics128,015 Posts1,055,334 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 70 Member | | Member Joined: Feb 2006 Posts: 70 | closes but will nor latch striker pin is there door mecanism works what the@#%*@ on a 62 carry all
bill
| | | | | Joined: Oct 2004 Posts: 15 Junior Member | | Junior Member Joined: Oct 2004 Posts: 15 | it would be easier to answer your questions if they were a bit descriptive.... your door closes, but will not latch? Have you tried lubing the mechanism? does it move? is it siezed? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | you need to remove latch from door & clean/lubricate it well,,I usually soak in carb cleaner then oil w/30w. brian | | |
