9 members (Otto Skorzeny, KCMongo, NJC, cmayna, JW51, MickeyP, HandyAndy, 32Fordpuchoptop, 1 invisible), 164 guests, and 3 robots.
Topics128,042
Posts1,055,505
Members48,424
#327340 01/27/2006 7:48 PM
Junior Member
Junior Member
I wrecked my 52 last year and ended up having to put a donor door from a 54 and new rear of passenger side of cab on it. New rubber has been installed. I cannot get the door to latch without slamming it hard, often repeatedly. Cracked my new glass. I have attempted to adjust the door latch mechanism but have not improved anything. What can I do to adjust the door and get it to latch securely and easily?
#327341 01/29/2006 11:46 PM
Hey, Bill
What kind of rubber did you install? I went crazy with my '54, trying to get my doors to close right and it all seemed to have to do with the rubber ... the door rubber from Chevy Duty finally set me right:
See My Notes -- Click Here
The other thing was learning how to play with the door latches & strikers ... I'm not sure if you have the same setup on your '52, but check this out, too:
Click Here
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
