6 members (Tom McGrath, Shaffer's1950, David Bush, Hotrod Lincoln, JW51, Gdads51), 86 guests, and 0 robots.
Topics128,051
Posts1,055,735
#327329 01/21/2006 11:35 PM
Is it nessessary to remove and reuse the old flat metal clips from the old window channels and reuse them on the new ones. If so, how do you "crimp" them in place without destroying the new channel. I removed all the clips and they are all in good shape, just wondering if I need to bother, or if the inside window frame and the channel screws are enough to hold the new channel in place.
Keith
If it were easy they'd have grade schoolers doing it!
#327330 01/23/2006 3:24 AM
or is it acceptable practice to put a small pan-head type sheetmetal screw through the channel into the window frame?
Keith
#327331 01/30/2006 11:46 PM
pakrat,
small screws can damage or bind the frame of the window. Use a small dab of silicone in 1 inch increments around the weatherstrip this is enough to hold it in place.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
