4 members (frogfarmer, dt235sd, Frank50, 1 invisible), 267 guests, and 6 robots.
Topics128,077
Posts1,056,012
Members48,433
#327318 01/09/2006 7:16 PM
I recently purchased a complete side window frame & glass assembly for my 1957 Chev pickup from LMC, (I really only wanted the frame - LMC was the only source I could find for chrome frames). But the price of the glass & frame assembled was only $10 more than the frame only. Since I already have tinted door glass, I removed the clear glass from the frame & installed my tinted glass. However, on disassembly of the LMC product, I noticed that the glass was held in place inside the frame by what appears to be a clear silicone adhesive.. The sealing around the glass-to-frame contact edges was what appears to be a black silicone of some type. As I was struggling to install the tinted glass into the frame with the window glass setting material I got from Chevy duty, I wondered why do it this way. It seems like using the silicone sealer would be faster, easier & just as effective. Has anyone ever tried this before?
#327319 01/09/2006 11:43 PM
I have used 3M window weld, the adhesive used in mounting modern windshields, with great results. Any good auto paint store will have it in fast or slow set for about 12 bucks a calk tube size. It's way messy but it's killer strong.
Richie Z:
Thanks for the feedback, I am going to give your method a try, makes sense to me.
3m window weld will work, but keep in mind its used to install windshields. So if you ever need to take the glass back out it will be a [censored] and will probably bend the frame trying. So on that note use clear or black silicone. It's only there to seal out water and wind.
thanks wilbur,
master technician
autoglass unlimited
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
Listen to Wilbur,he be the man on advice.End of question...........................
dan-pa
Bought some black silicone today. Thanks to everyone for the good advice.
wilbur - should i assume that silicon could be used to replace vent window glass as well? silicone sounds a lot simplier than the tape method.
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
I don't know... the black tape wasn't all that difficult.
Larry Bear
55.5 Chevy 3100 Panel
#327326 01/30/2006 11:42 PM
silicone it not a great adhesive. Your vent glass could fall out. that said the black tape aka tuff pak or packing tape is the best choice. It is available at any glass shop. The best size to use is 1\16. But not the cork lined.
