0 members (), 39 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#327305 01/17/2006 5:09 AM
Quick question for the experts. I just bought a 55 Chev half ton. One door is a little wrinkled. I know of a wrecking yard that has a similar truck, will a door off that truck bolt on? (its a 55-59, not sure exactly. can't remember if its a Chevy or GM either). Was there any changing of doors during those years? Thanks. smile
#327306 01/22/2006 6:48 AM
I did the same thing on my 59. I had a passenger door that was all busted up. So rather than fight with it, I just mooched a good one. As it turns out, the one I mooched was off a 55. The 55s have a slightly smaller screw attaching the interior regulator cover. The 56 and up use a bigger screw and there are about 14 of them. I replaced all of mine with stainless. That's the only difference I know of between the early and later doors. So its more likely you get a door with bigger screws in it.
#327307 01/23/2006 5:34 AM
Thanks! Thats not really to much of a problem though right? Just visual..minimal. Thanks!
Colin
