1 members (52Carl), 84 guests, and 4 robots.
Topics128,187
Posts1,057,315
Members48,468
Junior Member
Junior Member
my 51 has 6x9 holes cut in both doors is there any way to fix this
If the holes are on the bottom right of the inside of the doors, then they would be the door access panels. I think you can buy these new.
Sorry, I didn't see that they were speaker holes. The only thing I would know to do is to cut a patch panel from some sheet metal and weld it in.
And welcome to the bolt.
Welcome Medicmax to THE BOLT.
Good to see another Islander here. grin
Unfortunately I dont know of an easy fix for your problem short of replacing the whole door. frown
And you are limited to the unique 51 doors w/pull down handles and wing vents.
If your good with a welder,how about scrounging up a junk door or one thats been hit and cut the patches from the inside of it.
Regards
P.S. Where abouts on L.I.
Junior Member
Junior Member
i live in oakdale the only other thing i can think of is making a patch but i need a bead roller the hole cuts through 2 beads besides that the doors are super solid
Junior Member
Junior Member
no LI rust on my car its fron arizona
do you know of any junk yards around here where i can scrounge for parts
medicmax,E mail me I might be able to help
P.S. I,m in Amityville,Regards
